Re: Deck/sheer problem
Posted by Charlie on Mar 30, 2006
As a general rule the epoxy bond can be released using heat. I use a heat gun. Having said that I have to throw in the warning that using a heat gun is not very precise so great care has to be used to avoid popping some other joint that is not on the repair list. And it's possible to scorch the wood. If you have some scraps with epoxy joints it wouldn't hurt to practice first.
In Response to: Deck/sheer problem by A. King on Mar 30, 2006
