Re: OK so now how do i re
Posted by M Davis on Mar 29, 2006
If it were me I'd put what is left in the mixing cup in a warmer place for a couple of hours, or even better overnight, and see if it gets any stiffer before I declared the batch failed. My 2 1/2 year old MAS slow is still green as grass after 24 hours at 68 - 70 degrees F and "wetting your finger" wet after a couple of hours.
On the bright side, epoxy curing slowly is better then having it go off half way through wetting out your deck glass. Not that I know about that first hand...
Happy building, MD
In Response to: OK so now how do i remove by Petewp on Mar 29, 2006
