Re: Epoxy finish.
Posted by Charlie on Mar 27, 2006
I use a roller to apply both varnish and epoxy. The rollers I use, the cheap gray ones, always leave small bubbles in the surface. The bubbles or anything else that appears can be flattened by very light brushing of the surface with a bristle or foam brush. Once the product hardens with a bad surface your only way out is sanding.
In Response to: Epoxy finish. by Kev Robinson on Mar 26, 2006
