Re: Hatch Frames
Posted by LeeG on Mar 24, 2006
do you mean where the ribs should be located on the underside of the hatch so it's not too loose or have to be cut down?
I made about two dozen Chesapeake hatches once and the rough method I used was to ensure the ends of the ribs were about an inch back from the edges since the gasket tape was 3/4" inch wide. And sometimes you still have to trim the ribs.
In Response to: Hatch Frames by Vannessa on Mar 24, 2006
