Re: Slot Rudders
Posted by Alex on Mar 16, 2006
> so Alex, what is yr reaction?
Didn't get to paddle it much, just a bit of surfing.
> -wide slot?
Standard width slot.
> -lines/tillers/stuff exposed?
Standard "gas pedal" steering. Can't remember how it was otherwise rigged.
> -effective trailing edge size, effective rudder?
About 3/4 of the original skeg was rudder. Only a little more effective for turning than the skeg alone but the owner seemed quite happy with it - as I said, not enough paddling long distance for a really good analysis.
> -just a trailing edge attached to their typical skeg so fairly small?
> -trailing edge relatively perpendicular to path of travel?
A bit of "slope-back". The top edge of the rudder blade part was curved so that as the skeg was knocked back by an obstacle it would feed the blade back into the skeg-slot.
In Response to: Re: Slot Rudders by mick allen on Mar 14, 2006
