Pram Fillets and Glassing
Posted by Mike C on Mar 15, 2006
I am about to start the subject operations in the next few days. I have a few questions; 1. I realize you wait a few hours to smooth the bow and stern transom fillets but does it matter when you glass the bottom panel?(i.e. does it matter if the transom fillets are fully cured?) 2. I guess you cut the fiberglass along the bottom panel at the bow/stern fillets rather than have the glass extend over those fillets, correct? 3. Is it preferred to lay the cloth over the #1 plank fillet while it is a) wet, b) partially cured, c) fully cured or d) doesn't matter much. Thanks in advance - Mike
