Re: Varnishing
Posted by James Eager on Mar 8, 2006
When you do get to varishing I highly recommend the yellow foam roller (cut to fit a small roller frame) and a foam brush. Add a little penetrol to the varnish roll it on quick and thin and tip the bubbles out with the foam brush. This technique lets you move quickly and maintain a wet edge. I was amazed at how smoothing it came out (wet sanding between coats)...looks as good as any sprayed job. Everybody has there own little tricks...but all should try this method.
In Response to: Re: Varnishing by Tony Olsen on Mar 8, 2006
- Re: Varnishing by Doug Judd on Mar 9, 2006
What kind of nightmares? by Charlie Jones on Mar 9, 2006
- Re: What kind of nightmar by James Eager on Mar 9, 2006
- Re: What kind of nightmar by Doug Judd on Mar 9, 2006
