Re: Thanks much
Posted by David Bixby on Mar 5, 2006
I moved my Skerry, after it was stitched, out into the sun for a little photo shoot. The hull panels didn't budget but the wires made moving it a little touchy because the twisted ends act just like barbed wire. If you're not real careful you will damage yourself. You might consider doing your stitching so that all the twisted ends end up inside the hull.
In Response to: Thanks much by Mike C on Mar 4, 2006
