footbraces alteration
Posted by mick allen on Mar 2, 2006
I welcome comment(cut)
since you mention them, why not use the exact same line system as the cascade and thereby make brace adjustments simple, no bungee and no double jamcleats and jamcleat fumbling and no 2 diff line types. sure would be way simpler, cleaner, & less expensive.
like your single unadorned line would slide thru a hole in the pedal where now attached, down to an eye somewhere near the pianohinge pivot and then forward only to attach at the front of the rail or bulkhd. same otherside.
In Response to: brace & steer footbraces by jeff wong on Mar 2, 2006
