Re: Sleepless in the work
Posted by craig on Feb 3, 2006
The best thing that I've found is to raise the seat a bit to get the blood flow going correctly. Try putting a folfed towel under you, if that works some , try two. Then modify your seat accordingly. Raising the seat will also give you a better angle for paddling
In Response to: Re: Sleepless in the work by Rod H on Feb 3, 2006
- That reminds me... by Robert N Pruden on Feb 4, 2006
