Re: Awesome!
Posted by LeeG on Jan 9, 2006
Use foam bruses,,get a box for a discount price, bristle brushes lose about a dozen bristles onto sticky epoxy.
A ROS with dust catcher or better yet attached to a shop vac via a long hose will generate a LOT less dust than hand sanding. Hand sanding will send all that dust all around you. A ROS will at least catch most of it and attached to a shop vac will pull in what drifts away,,the discs also last a little longer.
In Response to: Re: Awesome! by Chris J. on Jan 8, 2006
- Re: Awesome! by Rod H on Jan 10, 2006
Re: Awesome! by Chris J. on Jan 10, 2006
- Re: Awesome! by Rod H on Jan 18, 2006
bristle brushes by LeeG on Jan 11, 2006
- Re: bristle brushes by Loren on Jan 11, 2006
- Outside exhaust by Mike D on Jan 11, 2006
