Re: Flush Hatches
Posted by LeeG on Dec 9, 2005
when making the wood tabs you can warm the pre-drilled and sanded pieces in the oven or under a light for about ten minutes. Then drop them in epoxy, swirl them around for a few minutes then string on a wire. This will soak the epoxy well into the wood.
In Response to: Re: Flush Hatches by Tony Robb on Dec 1, 2005
- Re: Flush Hatches by Tony Robb on Dec 13, 2005
Re: Flush Hatches by LeeG on Dec 13, 2005
- Re: Flush Hatches by LeeG on Dec 13, 2005
