Re: primer
Posted by Rod H on Nov 21, 2005
Well I put on the first coat of interlux's precoat and waited the alotted 16 hrs. Istarted to sand and the 120 gr. paper gummed up in no time. I tried other types of material with the same result.
I asked a pro painter about it and he said oil paint takes a good seven days to cure and to give it some time. I had applied it friday night and sanded with an R.O.S.. I imagine that if I ever get this first coat sanded down I may not venture a second coat of primer. Would this be a disaster? I've also picked up some penetrol to use in the top coat. Would using this in the primer help speed up the drying time?
Thanks for the previous input, Rod
In Response to: Re: primer by Chuck on Nov 17, 2005
