Re: "Filling the weave"
Posted by Marty Sullivan on Nov 20, 2005
I assume you would still use unthickened epoxy and squeegee the first coat, since the hull strength depends on a "tight" layering of glass - okuome - glass. Do you use thickener only on the fill coats? That would make sense since fill coats add negligible strength and can be lightened with micro baloons.
In Response to: "Filling the weave" by Rolf Nilsen on Nov 17, 2005
- Re: "Filling the weave" by terry on Nov 21, 2005
