no, it won't
Posted by Charlie Jones on Nov 20, 2005
It's just a waste of hardener. The cure method is totally different with epoxy vs polyester. Mix as close to spec as you can.
Now the Gougeouns DO recomend a slight additional hardener for epoxies used for coating water tanks, but that's the only place I ever recall any suggestion of not adhering to the proportions.
In Response to: Re: Keep it warm by Kevin Johnson on Nov 20, 2005
- Re: no, it won't by Mark Camp on Nov 20, 2005
- Re: no, it won't by Bill Brennan on Nov 21, 2005
