Re: Epoxy Blues
Posted by bubbacrawfish on Nov 14, 2005
Chris you have several options: 1. Use the force to control the epoxy. 2. If you can get your hands on a spaceship try to get as far away as you can from the earthís gravitational field. 3. Patience grasshopper. 4. Invest in a good sander.
Joking aside, make small batches and wait a couple of minutes before pouring epoxy. Make sure that all the glass is wet but donít worry if you can see the pattern. You can fill it on the next run.
http://thekayakhouse.blogspot.com/
In Response to: Epoxy Blues by Chris on Nov 14, 2005
