Re: Life of unmixed epoxy
Posted by RogerJ on Nov 2, 2005
Tim, I would suggest you warm it up before you use it. Measure the pumps out-put carefully to make sure they are OK or order new ones. The hardner may have darkened some but it should work OK as long as it has not become contaminated, same for the resin. I you are planning for a bright finish and it looks like the "old" product won't match you may want reinvest in new epoxy for the visible areas, use the older for under decks etc.. RogerJ
In Response to: Re: Life of unmixed epoxy by Charlie Tuna on Nov 2, 2005
