Heat Gun Glass Removal
Posted by Dave Houser on Nov 2, 2005
If you are trying to remove old epoxied glass it is possable to peel it off with a heat gun. Start at a corner with a putty knife and the heat gun and once you lift an edge grab it with pliers and pull normal to the surface and heat ahead of the bend in the cloth.
In Response to: Re: Heating Epoxy?? by Mike on Oct 31, 2005
