Re: Wet-out before fillet
Posted by Steve Miller on Oct 30, 2005
I pre coat before fillets. If you do not then the thick goo is likely to be a dry joint since the bare wood will suck any goo out of the fillet it can. I also precoat before glue joints get the thicker glue mix.
In Response to: Re: Wet-out before fillet by Howard on Oct 29, 2005
