Re: Sail for the MC 16.5
Posted by ben on Oct 26, 2005
I'm starting to build my first MC16.5 and want to add the sailrig, etc. I have several questions about your rig:
Do you have dimensions for the spars/sails, etc? where did you lead the jib sheet to on the hull? did you install a jam cleat for the sheet, or did you just hold it? how is the forestay attached and are there other stays for the mast? how is the jib halyard run, or is it a wire luffed construction?
thanks much
In Response to: Sail for the MC 16.5 by KirkE on Aug 9, 2005
