not to argue with CLC,
Posted by Charlie Jones on Oct 25, 2005
because on these boats with the epoxy it shouldn't matter, but normally you DON'T countersink screws into plywood. That just cuts away the outer layer of veneer. Normally you would drill a pilot hole and squeeze the ply under the screw head as you set it, thereby countersinking with the outer veneer intact.
In Response to: fuller bits by Eric on Oct 24, 2005
