another take
Posted by Howard on Oct 20, 2005
test fit the bulkheads. make sure the hull will come to the position you need with them in and sand the bottom corners to make room for a fillet. mark the exact position of the bulkhead with a pencil.
when i fillet and tape, i remove the bulkheads, fillet, tape, and then set the bulkheads in while the fillets are still soft. they can be glued in at that time as well or you can continue to wait. but have them physically in place when the glue for the chines and bottom is curing.
In Response to: Re: Add bulkheads later by John Short on Oct 20, 2005
