Re: Countersink Bolts
Posted by Dave Houser on Oct 14, 2005
I use tee-nuts to avoid haveing the bolt sticking out past the footbrace rail but you can just trim the bolt off at the face of the nut. I use a 2-1/8" hole saw to make plywood washers to reinforce the attachment to the hull.
In Response to: Re: Countersink Bolts by Eric Swenson on Oct 14, 2005
