fill those 1/16" holes.
Posted by dennis on Oct 7, 2005
After the copper wires are pulled, how would you fill those 1/16" holes so they would be less visible? They tend to be much darker than the surrounding plywood. I mixed wood powder from my sander with epoxy to use as filler, and the result is still not very good and is unpredictable at best. I will try to use flour (the food/cooking type) to see if it can be lighten up?
I would appreciate any suggestions.
Thanks,
dennis
