Re: Rudder Mount
Posted by LeeG on Sep 29, 2005
I don't have a double rudder mount. Look around kayak shops. The most common kind is a 1/2"x4" strap of aluminum bent at the ends with a thin rod providing the pivot between the horizontal tabs,,the strap is oriented vertically on the stern. The mount that I saw on the Chesapeake triple looks like two hinges and it's screwed on either side, I believe the one they used only had one half but it appeared to work. Your MC16 probably doesn't need as substantial of a mount since they one on the demo ChIII was being used with a sail rig.
In Response to: Re: Rudder Mount by raul on Sep 29, 2005
