Re: Planing scarf joints
Posted by Jeff on Sep 26, 2005
Have not tried one for this, but have run into other woodworking situations where the hand tools end up netting far better than power tools. It really does not take too much effort to do the joint. I set up multiple joints in a stack, not just a single joint, so it went really fast, but a really sharp plane is the key. At only a few millimeters thickness, it also would not take too much to mess up *really* fast with a power tool and with the lengths required for the hull, a trashed joint ends up not leaving enough for making the long pieces. You could end up trashing some pretty expensive wood that cannot be reused,unless you want a whole lotta bulkheads.
In Response to: Planing scarf joints by Larry Price on Sep 26, 2005
- Re: Planing scarf joints by terry on Sep 26, 2005
Re: Planing scarf joints by Steve Miller on Sep 26, 2005
- Re: Planing scarf joints by don on Sep 26, 2005
- Re: Planing scarf joints by Chris on Sep 26, 2005
- Re: Planing scarf joints by RogerJ on Sep 26, 2005
