Re: skeg box
Posted by CLC on Sep 22, 2005
I haven't scrolled through all the responses, but the reason for the wooden pivot is so that you can epoxy it in place and eliminate the possibility of leaks in that inaccessible spot. In hundreds of these things I've never heard of the pivot failing; the stresses (and wear) are low.
In Response to: skeg box by Dan on Sep 21, 2005
