Re: Shop Cam of Sheer wat
Posted by John Short on Sep 21, 2005
The reason it's a hybrid is that hull is typical stitch and glue while the deck is stripped with cedar strips. Makes for a beautiful boat, but adds in difficulty in assembling as the deck is built onto the hull, then removed and the temp forms are removed from hull then deck re-attached. The way I see it will be an assembly like Pygmy where the inner seams will be taped and glassed, meaning a huge PITA, unless someone knows a trick to simplify this action.
In Response to: Re: Shop Cam of Sheer wat by Brad Shook on Sep 21, 2005
- the trick by LeeG on Sep 21, 2005
- Re: Shop Cam of Sheer wat by FrankP on Sep 22, 2005
Re: Shop Cam of Sheer wat by LeeG on Sep 26, 2005
- Re: Shop Cam of Sheer wat by terry on Sep 26, 2005
