Re: Paint Weight Etc.
Posted by J.Schott on Sep 20, 2005
The Piankank River is located between Gloucester and Middlesex counties. I timed it from Hampton to my parents driveway and it took me about 45 minutes driving north on 17. I used Brightsides paint and primer. The penetrol was added to the paint. Put the maximum recomended amount of thinner in the primer also, it helps it to cure fully. One bit of advice, don't use any type of thinner on Brightsides. I know the directions recomend wiping down with thinner, but it will wrinkle up almost immediately. I just washed with water after wetsanding. Good luck with the paint job, you're on the homestretch now!-Joey
In Response to: Re: Paint Weight Etc. by Chuck on Sep 20, 2005
