Re: panel joints, epoxy
Posted by John Foster on Sep 19, 2005
If they are partially cured a heat lamp will soften the mess up. And then perform above vinegar trick. This won`t be the last mistake you make on this project so be aware just about every miscue can be worked around.
In Response to: Re: panel joints, epoxy by Mac on Sep 19, 2005
