Take it off, take it ALL
Posted by Charlie Jones on Sep 18, 2005
off, as an old razor commercial used to say.
It really all needs to come off in order for the epoxy to get a good bond. After you sand off as much as possible, the remaining varnish can be washed off with lacquer thinner or acetone. Do that outside if possible, otherwise with good ventilation. Neither will harm the cured epoxy. Then sand the epoxy to a dull look and run your skim coat.
In Response to: epoxy and varnish by TomW on Sep 17, 2005
