Re: Ches 16 alterations
Posted by Brad on Sep 15, 2005
When you take the inch off the shear panel you'll also reduce the length of the boat because of the angle of the bow. It's odd that the specs sthow the 17lt only 1 1/4 inches shorter than the 17 and the 16lt is 4 inches shorter than the 16.
In Response to: Ches 16 alterations by John Short on Sep 15, 2005
- Re: Ches 16 alterations by Paul on Sep 16, 2005
