Re: I Use Wood Glue
Posted by John Foster on Sep 13, 2005
I don`t know if you will pick up on this, but have you used the Titebond to glue the panels together after they have been wire stitched? It would be much faster and easier than mixing and spewing epoxy mix. I am a novice and ended up with a lot og wires glued in place. No biggie but I could have saved myself a lot of time and aggravation. I just thought I had better follow the directions. A novel idea,no? I like your modification creativity. Hope things are good in Tejas!! John F
In Response to: I Use Wood Glue by Kurt Maurer on Sep 10, 2005
