Re: Cove and bead not nee
Posted by Dave Houser on Sep 13, 2005
The bevel is preferred between strips when installing accent stripes in order to maintain a crisp smooth line after sanding the wood fair. You only have to bevel on side at each joint with a couple passes of a block plane.
In Response to: Cove and bead not needed by mwagar on Sep 13, 2005
- Re: Cove and bead not nee by craig on Sep 13, 2005
