Re: A 75 lb MC 16.5!
Posted by raul on Sep 7, 2005
I believe it could hold up your weight, no problem. From my novice perspective. All these materials are incredibly strong and once everything is glued and fiberglassed together, very rigid. I wouldn't jump into it or on top of it with all the weight bearing on the small area of a footprint. I wouldn't do it even with my 165 lbs. I would use fiberglass cloth on the inside also (cockpit floor area)with 3 coats of epoxy. If you ask CLC directly you get a professional answer. Enjoy, it's wonderful kayak!
In Response to: Re: A 75 lb MC 16.5! by Larry Price on Sep 7, 2005
