Re: sanding
Posted by Howard on Sep 3, 2005
after you have finished this round of sanding, i would put one more layer of epoxy....but applied with a squeegee (a plastic spreader). this does a great jo of filling the little shallows and putting only the thinest of material on the already high areas. its the easiest way to get to a great finish.
after the last round of expoxy with a spreader...it should only take a quick round of 180/200 grit on the Random Orbital Sander (ROS) and then you should be ready to go. But be careful on the edges with the sander not to sand through.
hs
In Response to: sanding by Adawg on Sep 3, 2005
