Re: separating scarf join
Posted by Howard on Sep 1, 2005
either works...my preference would be wax paper because it is a bit stiffer than plastic wrap...so it is easier to work with and inspect your joints from the edge.
as you do this step (making a stack) it is really useful to make some kind of alignment marks somewhere outside of of the area where you will be applying the weight that you can easily see that you have stacked the panels exactly where you wanted them. so rehearse the step all the way to putting the weight on it so you will know how it all is supposed to go.
hs
In Response to: Re: separating scarf join by Pete on Sep 1, 2005
- Re: separating scarf join by Laszlo on Sep 2, 2005
Re: separating scarf join by Steve Miller on Sep 2, 2005
- Re: separating scarf join by Moe on Sep 2, 2005
- Re: separating scarf join by jamie on Sep 2, 2005
- Re: separating scarf join by Pete on Sep 3, 2005
- Re: separating scarf join by Toby on Sep 4, 2005
