Re: How light is light?
Posted by terry on Aug 30, 2005
One other comment: If you have a carbide scraper, go over the entire hull with it to remove an drips, nubs and bumps prior to sanding. This will save a lot of sanding and minimize the tendency to sand into the wood when you're trying to ROS down a high spot.
Then apply the last epoxy coat warm and very thin. You'll be glad you did.
good luck
In Response to: Re: How light is light? by Andrew K. on Aug 29, 2005
