Re: How light is light?
Posted by Kyle T on Aug 27, 2005
At this stage I would alter my plans a little if I was you. You no doubt still have some weave texture in your epoxy or you wouldn't need another coat. I learned for Kurt that just adding more epoxy at this stage is just adding weight.
Use 320 grit and sand the entire hull down to smooth just enought to remove any texture. You may touch the glass in spots but that won't matter. Now add a skim coat of eposy with a squeegy. This will net you the lightest layup you can get with the glass you are using. And it will still be just as strong.
Hope this helps. --KT--
Lightweight tandems
In Response to: How light is light? by Andrew K. on Aug 26, 2005
- Re: How light is light? by Andrew K. on Aug 29, 2005
Re: How light is light? by terry on Aug 30, 2005
- Re: How light is light? by Mark Camp on Aug 30, 2005
- Re: How light is light? by Mac on Aug 31, 2005
- Re: How light is light? by terry on Sep 1, 2005
