Re: bright finish scratch
Posted by John Foster on Aug 25, 2005
For small scratches use Wet or Dry sand paper, rubber sanding block, 400 grit and then 600 grit, then auto rubbing compound. For re varnishing the above threads. With the Wetordry paper of course use water, and lots of it. You can clean out the clogged sandpaper with a scrub brush as you go along before the paper is worn out. I try to remember that my time is more valuable than sheets of sand paper so I don`t use the same sheet forever, it`s counterproductive. This is from years of auto refinishing. Have at it!!
In Response to: Re: bright finish scratch by Doug Judd on Aug 25, 2005
