Re: End-Pour Results
Posted by LeeG on Aug 25, 2005
It would require only a couple oz of epoxy in either end if a small wood wedge was placed in the ends under full length sheerclamps with excess goop generated during filleting. Thereafter when the the ends are rounded over and the through hull hole is made a little more sealing/glassing will finish things without needing to pour 12oz of foaming(sys3)or overheating(MAS) epoxy into wide open triangular sections.
In Response to: Re: End-Pour Results by Mark Camp on Aug 25, 2005
- Re: End-Pour Results by Hank H on Aug 25, 2005
Re: End-Pour Results by LeeG on Aug 26, 2005
- Re: End-Pour Results by ben on Dec 9, 2005
- Re: End-Pour Results by J. Schott on Dec 10, 2005
