Re: bright finish scratch
Posted by Steve Miller on Aug 24, 2005
Depends on the depth of the scratches or how long you want to sand. Most guys just do it once at the end of the season. 400 grit wet is what I do between coats of varnish. For bigger scratches I might go 320 also wet. I like to wet sand varnish since it clogs so bad sanded dry.
In Response to: bright finish scratches by jim nelson on Aug 24, 2005
- Re: bright finish scratch by Doug Judd on Aug 25, 2005
Re: bright finish scratch by John Foster on Aug 25, 2005
- Re: bright finish scratch by jim nelson on Aug 25, 2005
