Re: draping fiberglass
Posted by Kurt Freewald on Aug 22, 2005
Thanks Lee for the advice. Let me be sure I understand what you mean. So you squegee the entire hull and leave about 2-3ft from the bow and stern un-squegeed. At that point you trim the fiberglass one and a half inches around the entire perimeter of the boat. Now, does that include where the keel angles up to the tip of the bow...so your sorta cutting a slit and folding the fabric at the slit edge around the tip, then the other slit edge on top of that one... and you do the same for the stern? . Also, if this is correct, its ok to layer the fiberglass? Im probably making a big deal out of something thats really simple, i just dont want to mess this step up. thanks for all the help. Kurt
In Response to: Re: draping fiberglass by LeeG on Aug 22, 2005
