Re: Outside hull fillets
Posted by LeeG on Aug 22, 2005
My $.02 is that when you round the chines enough you'll cut into the innerveneer anyway,,beveling the panels before stitching will reduce the amount of exposed veneer considerably but s&g is plywood, it's unrealistic to give the impression it's not by reducing the amount of exposed veneer with sharp chines.
In Response to: Outside hull fillets by Kurt Freewald on Aug 21, 2005
