Outside hull fillets
Posted by Kurt Freewald on Aug 21, 2005
Hello,
I just finished sanding and now am getting ready to feel the outside keel and chine seams with thicked epoxy. The problem is now that my chine seams are rounded there is almost no groove for epoxy to fill. Only the keel has a groove to be filled. Do I still need to fill them? the 2nd question I have: there are small black lines along my outside keel and chine seems from sanding.. Did I sand to deep? I wanted a bright finish but am not sure now how these black lines will look. I guess the way it looks now since the fiberglass is clear. Has anyone else run into this?
thanks, Kurt
- Re: Outside hull fillets by Dave on Aug 21, 2005
- Re: Outside hull fillets by Ed, NY on Aug 21, 2005
Re: Outside hull fillets by Kurt Freewald on Aug 22, 2005
- Re: Outside hull fillets by Doug Judd on Aug 22, 2005
- Re: Outside hull fillets by LeeG on Aug 22, 2005
- Re: Outside hull fillets by CLC on Aug 22, 2005
