Re: Small bulge between s
Posted by Howard on Aug 19, 2005
best to post that picture...
if you are painting your hull you can be rather agressive in dealing with this sort of discrepancy...if you are going for a clear finish, you are a bit more limited or it takes a lot more finesse to fix a problem like that at this stage.
fwiw, as the builder, you are proably much more aware of minor idiosyncracies than anybody else who would be taking a look at your boat. You probably don't "need" to fix it from a structural or boat handling persspective. it takes quite a bulge in the context of a 16 foot kayak to impact its structure or paddling characteristics.
so lets see the picture...its probably not that bad.
In Response to: Small bulge between seams by Andrew King on Aug 19, 2005
