Re: slow drying varnish
Posted by J.Schott on Aug 13, 2005
What varnish are you using? If it a 2 part system, improper ratio is probably the culprit. If it is captians or something similar, that may be a question for the manufacturer. I have only used captains varnish and have applied it in similar conditions that you have with no problems. The only thing that is keeping me from putting some on my boat is that it's so stinking hot here. Can't keep from sweating all over my work!-Joey
In Response to: slow drying varnish by Jim H on Aug 13, 2005
- Re: slow drying varnish by Steve Miller on Aug 14, 2005
- Re: slow drying varnish by Jim H on Aug 14, 2005
