Re: Epoxy Flaking
Posted by J.Schott on Aug 11, 2005
Yup, as Bubba and Matt said it has to come off. I had the same thing happen as well, and careful sanding is the only solution. My problem was with the first fill coat and was also probably caused by humidity. I know it's a step back but it not "unrepairable". I sanded mine with 120 grit to slow down the removal process and save as much of the cloth as possible.
In Response to: Re: Epoxy Flaking by Matt Croce on Aug 11, 2005
