epoxy runs ...
Posted by dennis tran on Aug 3, 2005
Putting epoxy resin onto deck and hull turn out rather a frustrated experience for me. Except for the first coat where the fiberglass cloth soaked up all the epoxy -- no run, no mess.
But the when I put on the second coat with either disposable roller or foam brushes, careful as I could possibly be, I spent time to catch all the drips and excess. But the next day when I examined the underside of the kayak, there would be hardened runs/drips that will need to be sanded off.
I think part of the problem is the slow-curing epoxy that would have all the sweet time to run.
Is there a better way to do this besides foam brushes and rollers?
- Does this indicate that I used too much epoxy?
- Should I put masking on the underside to catch these runs?
- Doing so, would I run into the problem that I potentially cannot pull the masking tape off when the epoxy is dried?
Thanks in advance.
dennis.
- Re: epoxy runs ... by Chris Taylor on Aug 3, 2005
Re: epoxy runs ... by LeeG on Aug 3, 2005
- Re: epoxy runs ... by Chris Taylor on Aug 4, 2005
Re: epoxy runs ... by Mike on Aug 5, 2005
- Re: epoxy runs ... by Chris Taylor on Aug 8, 2005
- Re: epoxy runs ... by LeeG on Aug 3, 2005
squeegee get my vote by Gober on Aug 4, 2005
- Re: squeegee get my vote by Kurt Maurer on Aug 4, 2005
- Love the sqeegees by Doug Judd on Aug 5, 2005
- Re: Love the sqeegees by RogerJ on Aug 8, 2005
- Re: Love the sqeegees by cosmo on Aug 10, 2005
