re thread - leaky hatch
Posted by Ray on Aug 3, 2005
Jim suggested the following as a solution.
I followed instructions and will report back tomorrow.
ta
ray
Hi Ray, I just read your message about leaky hatches and I thought I'd share a trick that I've used for model airplanes. When the wing is mated to the wing saddle, there often is some variation between the surfaces. To close the gaps, silicone gaskets are the easy way to go. Put a thick bead of silicone down and then put plastic wrap (from the kitchen) over it and then put the wing (hatch) in place and let it set up. After it is set up, the wing (hatch) can be lifted, the plastic wrap discarded and the resulting gasket should be a perfect fit. Hopefully, this would work for a kayak hatch, also. I've been contemplating using this on mine, but as of yet, I haven't tried it. Good luck, Jim
- Leaky hatch - RESULTS by Ray on Aug 4, 2005
- Re: Leaky hatch - RESULTS by Moe on Aug 4, 2005
- Re: Leaky hatch - RESULTS by LeeG on Aug 4, 2005
- Sure It's The Hatch? by Kurt Maurer on Aug 4, 2005
- what?!?! by LeeG on Aug 4, 2005
- Re: what?!?! by Kurt Maurer on Aug 5, 2005
- and all this time by Crystal on Aug 5, 2005
